I have just installed a shower/steam enclosure, the ones that you do not fix to the wall so they can be easily pulled in and out. The waste what come with the enclosure is a fast flow flexible waste, the pipeing on it is not like the ones where you can adjust in and out. I need to shorten this waste so that the water will flow properly. Currently it is the full size and connected to a 40mm compression coupler. On the end of the fast flow waste pipe it goes to a straight insert which fits into the compression so you get a seal. What my question is if I need too shorten this and cut the waste it will loose the insert. Is there a way to shorten these flexible wastes ?
Thanks in advance
Thanks in advance
