OK, so apologies in advance for what's going to be a long-ish post.
FWIW I'm a reasonably competant DIY-er, but I don't have any decent test gear, just a standard meter
Things started on Thursday afternoon, when the RCD tripped out. After a lot of chasing, it was determined that the lights circuit has a fault. I checked for water in the two outside lights, loose connections and obvious damage & then reached the limit of what I can really do & called the electrician.
He was only able to do two hours this morning, but the fault has been isolated to the string of three lights after the kitchen, ending in the outside lights. (Proabable culprit I suspect)
In the course of this fault finding, we've basically discovered that the electrics are extremely untidy to say the least. Nothing majorly dangerous (AFAIK), but a mess. The house has also always been short on sockets.
I queried whether it would be possible to switch the lights onto a RCBO, and his opinion was that going that route, it'd be better to do a a swap for a full RCBO board, which is something I'd consider.
The current CU is a Volex Protector, ~20 years old. Main bonding is in place to both gas & water. Circuits look like this (L-R):
32A cooker (4mm2 I think)
32A shower (4mm2)
16A radial, downstairs sockets x5
16A radial, upstairs sockets x4 & model railway loft socket through 3A FCU
16A 'lollipop' (4mm2 to kitchen, then 2.5mm2 ring) kitchen sockets x6 & boiler
16A unlabelled, I *think* this does the socket behind the fridge, although I'm by no means certain.
10A lights (1.5mm2 cable)
I know there are junction boxes *everywhere*; we found three under the landing in the process of looking for the initial fault, and I'm aware of two more in the loft and one under the floor. (Socket circuits all seem to be wired to a JB then to the sockets in a star pattern. Lights all appear to have 1 JB per fitting from a central JB)
He was of the opinion that the junction boxes and general mess of wiring wouldn't make any difference to changing to an RCBO board, and that once this issue is fixed, it'd only take 2-3 hours to swap and test the remaining circuits, at which point he could add another 4 socket radial downstairs in about an hour.
Does this sound relatively reasonable?
The junction boxes everywhere syndrome does concern me a little, as does the kitchen lollipop.
32A shower (4mm2)
