Hi
recently we have had a few problems with our heating / hot water supply.
firstly the float valve in the loft tank seized not letting any hot water into the tank (solved that problem).
Then we had no heating or hot water? replaced tank stat but then could only get hot water?
Fault was found to be the 3 point motorised valve heating and hot water Yippee.
Now occasionally the heating causes the fuse to trip in the consumer unit?
I checked the heating pump earlier when the heating was supposed to be running however the pump was not running but i could hear the buzzing of the electric running to it? could it be this that causes the fuse to trip?
Is it possible that a heating pump could occasionaly seize??
any help would be gratefully received.
we have had an electrician out and he could find no fault with the wiring to the heating system?
