I believe I have a faulty hot water cylinder.
Basically, my small header tank in the loft has been overflowing through the pipe to the outside.
Ball valve has been changed and tests done to see if the excess water is coming from the vent pipe but neither were guilty.
I switched off the heating controller to rule out an issue with the pump as well.
Still it overflows.... And I have left it quite a while.
I've been told that the cause of this can be perferations in the cylinder internal piping causing outer cylinder water to be forced in the pipeline and pushed back up into the small header tank.
Before I call a plumber to come and change my hot water cylinder, I just wanted to check with you all whether there's something else I should be considering or further tests I could do?
Thanks in advance.
Thanks in advance.
