Last week my boiler wouldn't start. Bit the bullet and signed up to Baxi repair and support but on inital inspection the guy said there was an airlock in the system which was turning the boiler off. He bypassed the switch to get it running thus proving the boiler was fine.
I ran the system for a couple of hours and bled the radiators. The room thermostat turned the heating off but later it wouldn't come on again. I could hear the relays in the thermostat and programmer click, MV move and water starting to be drawn into the boiler but it wouldn't fire. It seems to constantly draw water but not fire so I killed the power to prevent issues and used the immersion.
A few days later I decided to have another look at it, I poked my finger in the header tank feed pipe, bled the pump and vented it. I also turned the pump motor down to setting two and back up to three and the boiler fired back up - yay!
I then turned all the rads in the house up to full and spent the next four hours removing lots of air from the system. After this point it seemed to come on/off as normal but the next day it stuck again, this time I hit the pump (lightly) with a screwdriver and turned the motor down to two and then back up to three and it started again.
From this point it has been fine however a fuse has been tripped in the house this morning which is very unusal.
So my question is, do pumps start to exhibit these issues when they begin to fail, is tripping a fuse common if the motor starts to overwork, gets stuck etc.?
Initally my plumber felt if all the rads in the house were heating up the pump is working correctly but it seems strange a fuse has now gone.
