Fed up with leaking storage units!
7 Sep 2008
Kent
In the spring I bought two small plastic storage units (different manufacturers) for the garden. They were kept on the patio and I stored small tools, pots, liquid fertilisers etc. in them. As they were always quite dry inside I made the mistake of using them for other stuff like cushions and my power tool batteries. Now the interiors are wet with pools of water in the base and wet shelving. They are the ones you assemble in situ and fit together with wedges that you push into the joints.
Can anyone recommend similar units that don't leak? Both are smallish, 1.40m. high and about a metre long. Anything roughly that size will do. A shelf or two would be needed.
