Hello All, following on from my post about boilers...
Our system has been pumping over for quite a while, most rads are sludged! I have identified the problem as the pump is sucking water from the F&E tank, the cold feed to the system joins about 12" from the pump. It is a single pipe system, rated about 250kw, the vent pipe is on the flow from boiler.
We have fitted a speed controller on the pump, but that made no difference,
I have thought about converting it to a sealed system, but given the age of it (75yrs) i thought best not too.
Any ideas how to stop this problem?
Thank you as always
Peter
Thank you as always
Peter
