My TF1 is leaking and upon inspection it appeared to be coming from where the metal drain valve screws onto the plastic body. There's somewhere to place a spanner, so I decided to tighten it a little, but it still leaked. So I decided to remove it, clean and check for possibe causes.
After
I did this, I went online and found the instructions and discovered this rather worrying sentence, 'Drain valve. Factory fitted do not remove' Doh!
Anyway, it's done. So I'm thinking a bit of PTFE tape and screw it back on, hoping for the best? Or do you think it's now goosed and will need replacing?
After
