Got some great tips from here in the past so hopefully you guys can help me out now.
I am attaching a 75mm post to my exterior house wall. I am planning to use 3 x anchor bolts but not to sure what length to get, is 100m enough say 40mm in the post and 60mm in the wall. The post will only be supporting a 60cm piece of featheredge fencing hence only using 75mm.
I am then putting another piece of small featheredge fencing in, 90cm. This will be on arris rails and on a slope of about 40 degrees. As the posts won't be morticed what is the best way of attaching the arris rails as the brackets will obviously not match up (or can you just bend the bracket to the angle) Hope that makes sense!
Thanks in advance,
Andy
Thanks in advance,
Andy
