I bought a new tap, it accepts a 10mm tap tail. I got the tap second-hand but it has never been fitted. The tails with it are copper tube and also there are tails with a plastic speedfit-like system. I want to have a plumber come and fit isolation valves under the sink on the tap feeds. I have bought isolation valves with compression fittings suitable the existing pipework on one end, and flat-face BSP ready for flexible tap tails. (https://www.toolstation.com/flat-faced-male-straight-isolating-valve/p95064).
So I need to buy flexible tails 10mm on one end and 1/2 BSP on the other to attach to an isolating valve with a flat face. It seems such a thing is not sold at Screwfix, Toolstaiton, and plumbers merchants. Why is that so, it seems like a handy thing to use?
It can be got on eBay, from, for example, a seller called Flabbyrabbit. But that name doesn't exactly fill me with confidence in the product. (https://www.ebay.co.uk/itm/266996657736).
The driving force on all this is that I want to be able to remove the taps easily in the future and fit a new sink, without the need for a plumber.
For some reason I don't seem confident enough to do a compression fitting. Probably the reason has to do with the trickiness of cutting and preparing copper tube (or in my case stainless steel).
But, having thought about it carefully if I get a regular isolation valve (not flat-face) the compression fitting I would need to make would be between two steel items (the output side from the isolation valve and the input side of a flexi-hose) so it should be easy to do, right?
Can I guess that the reason no flexi hoses with flat-faced BSP are available is that WRAS won't approve them?
Cheers
Cheers
