Background: I've got a monobloc tap in the kitchen sink which became progressively more wobbly as the backnut loosened. There wasn't enough room to get a spanner to tighten it, so I put up with it. But now I've discovered the hot water is leaking from the bottom of the tap, where it connects the the tap tail. The cause seems to be the constant movement of the tap which has caused the tiny O ring to perish.
The hot water feed service valve is about 200mm directly below the tap, so a rigid tap tail fits nicely. The cold water valve is off to the side so I currently have a rigid tail, going to a 15mm compression x BSP F union flexible, which connects to the cold service valve.
So, I've decided to get a couple of flexible tap tails to fix this. The only problem is that I seem to have bought tails which have a 15mm compression joint, but i want to connect directly to the service valve (male thread).
I think the answer would be to use a flexible tail M12 male x BSP F union, but this type of connector doesn't seem to exist.
I'd be grateful for any suggestions.
Thanks,
Bob
Thanks,
Bob
