- Joined
- 24 Oct 2026
- Messages
- 1
- Reaction score
- 0
- Country
Hi all,
I've got an old Fifos 12kW electric boiler (made by Fifas Ltd, Perth, model XA0052/12UB) that's been switched off for a long time. Now it won't run. It seems to trip on a "no water" fault, presumably to protect itself.
Setup, as far as I can tell:
Thanks in advance. Happy to post photos.
- Vented cylinder with an immersion heater, acting as the hub, I think as a thermal store
- Wood stove with a back boiler; a flue thermostat switches its pump on when it's hot
- Two sealed circuits, each with its own expansion vessel, gauge and filling loop: one for the electric boiler, one for the radiators
- Three pumps in total
- A simple on/off control in the kitchen for the electric boiler
- Fixed a leaking filling loop valve on the boiler circuit, and I'm repressurising it to about 1.3 bar (it was at 0.5)
- Opened the automatic air vent above the boiler, but nothing comes out, neither air nor water
- Is there a specific priming or refilling procedure for Fifos boilers after they've been drained or off for a long time?
- I understand these use electrode-style heating. Does the water need any particular treatment or conductivity to work, and should I avoid normal inhibitors?
- Does anyone have a manual or wiring diagram for this model?
- Can anyone recommend an engineer in Aberdeenshire who knows Fifos or electrode boilers?
