Hi
I'm making some permanent units out of 25mm MDF from a supplier who primes/undercoats from the factory. Of course, I'll be making cuts etc so have some primer and undercoat, and will gloss over
I may spend time dowling most the joins but I'll be stuck with the odd screw I need to put in, and may need to pocket-hole a few too. As its all going to be painted I'm not going to stress if I can't figure a way of hidden fixings.
But I've never filled wood or MDF (!) - never needed too - normally engineer a way around it.
Any recommendation for a filler for covering screws and pocket-holes? Would rather a recommendation than a random purchase. Assume fill/sand/then re-prime/undercoat/gloss with fine sanding between.
Not sure on difference between 1 or 2 part? And want something that can be sanded nicely and not set like granite
