View media item 96505When installing a boiler with pipes ran behind the boiler by a stand off kit. I am guessing it is had to install a filter. In situations like in the picture.
Is a filter needed?When installing a boiler with a stand-off kit and intending to add a filter, it helps to plan ahead and make sure you leave enough room above the boiler to fit the filter....
That's a question only the installer can answer (assuming the installer is competent of course)Is a filter needed?When installing a boiler with a stand-off kit and intending to add a filter, it helps to plan ahead and make sure you leave enough room above the boiler to fit the filter....
