Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Its a while since I had the panel off but I think I remember that each zone had a limit of X number of magnetic contacts and 1 PIR
could a failing one be affected by the light as mentioned.
Jesus ….you said it was a door contact , now you’re saying you also a pir on the same zone ! I would be looking at this first as you said it happens when it is hot ! ….
You are right - sorry but I as I have had problems with door/ window contacts in the past I automatically thought of them and overlooked the PIR which I have never had any issues with.
So in circumstances like mine with intermittent false trigger on a zone with any number of magnet contacts and just 1 PIR then you would always head straight to the PIR and start there
For now until I have more time could I just stick a piece of insulating tape on the sensor. It actually points at something that already has a magnetic contact anyway so I could do away with it all together.
