hi everyone
need some advice on installing a fire detector into my alarm system.
My equiptment
alarm panel :- accenta metal gen4 lcd
fire detector :- system sensor ECO1002
relay base :- system sensor ECO100BREL12L
as far as i understand from the wiring diagram
i connect the +ve and -ve from the alarm panel to the relay base,
i connect the alarm sensor connections to the relay terminals on the relay base,
then after testing i install the detector onto the base.
what i don't understand is how the relay base and the fire detector work together.
how does the detector trigger the relay in the base ?
how is the detector led connected to the base led terminals ?
is the the detector opened via the back to access any connections to it ?
the fire detector and base is the latching type, is the detector reset through the alarm panel or by some external means ?
i have never wired a detector with relay base before so if anyone has experience wiring up the detector and panel that i have , i would appreciate their input
thanx shadrock
My equiptment
thanx shadrock
