Fire Place Opening PT2 (with Pics)
22 Jan 2007
Hey all, got a very small amount of time off, so got props in and opened fireplace up a bit to accomodate log burner,
at the moment, the opening is now 650mm wide (600mm say by the time it cemented up and tiled/covered) which gives the stove manufacturers minimum clearence of 100mm either side of the stove ok. but reckon it will still look a bit tight.
the pics below, show the throat of the chimney which appears to be stone, with bricks that I belive were added in later for a previous opening working up to the throat. from what you can see does it look like I could remove one set of 1/2 bricks either side? which would leave enough to fill up to lintel and give good overhang 200mm+
coloured in the area I'd like to remove
img_9108-jpg.117256
img_9181-jpg.117257
img_9179-1-jpg.117258
img_9180-1-jpg.117259
img_9173-jpg.117260
img_9178-jpg.117261
img_9166-jpg.117265
img_9179-jpg.117264
img_9167-jpg.117263
Your pics wont open up for me?
Neither will your postings to locate any previous Part 1. reference to this work/thread?
If there are previous, why not keep them all on the same thread?
