- Joined
- 3 Jun 2016
- Messages
- 128
- Reaction score
- 3
- Country
I've got a 1930 house with solid walls. At the moment the chimney breast has a hole where a fireplace should be. Last week I ordered a new gas fire and a stone surround and was told prior to installation the fitters would require me to lift up some of the laminate around the chimney breast which I have now done. There is now a smell of damp and looking at the source I think the concrete base that comes out from the chimney into the room about 15" or so is very slightly damp to the touch, certainly very cold and a few of the floor boards around it show staining up to around 3" away from the concrete base.
I lifted a bit of the boarding to the left of the breast where the gas pipe is and the ground is perhaps 2 to 3 ft down below, doesn't look wet and there are cob webs a spiders. There is a fair bit of air flowing through underneath however because of the venting bricks. Also the fireplace hole and the bricks around it seem dry.
I am wondering if moist air from outside has been blowing through under the floor and has been condensation on the underside of the concrete and over time leeching through.
I'm now a little concerned that a fireplace is due to be fitted in the next few weeks and I have this issue.
Any idea's if my guess is correct or not and how I would go about sorting the issue out.
