Hi all, a lot of the plaster on my fireplace was loose so I knocked it off to see what was underneath. see image.
What I'd like to do is make this into a built-in space; actually a bookcase. I noticed the arched brickwork which if I'm right is a type of lintel. What I wanted though was to make the space bigger than the original fireplace by adding a lintel higher up (see red outlined area on image) and removing the bricks below (highlighted in faded white) so that I can then board the space out and make bookshelves with door fronts to finish.
Is this possible, what lintel do I need and do I need building consent? etc
The house was built in 1938 and is a semi-detached with the chimneys of both houses running up the centre of both houses. The chimney breast is about a third of the size (width wise) upstairs in the bedroom above.
