fits a combi boiler on micro bore central heating system?
27 Nov 2004
I would like to know can i fit a Combi Boiler (Potterton Gas performa 24)
to my micro bore central heating system 10mm?
If so, any special fittings requirement for that?
Many thanks in advance.
really? that good
So i can just change the boiler and just connect it back to the existing central heating?
The pipe from the boiler needs to be say 22mm, presumably it is already. That would go to a "Manifold" - a point where several thin pipes are taken off the 22. It is important you don't join into a 10mm pipe and expect the boiler to get the heat out!
you cant just swap boiler if existing system is a vented system.you need to convert the existing system to suit combi.
