hi guys,
hope you can offer some advice.
i fitted a solid oak floor for a mates mum. the flooring was approx 10mm thick. it was layed on a bitumen coated floor using laybond flooring sytems L16 wood bond.
problem is this was the way i was shown to lay this type of floor by a joiner in another house but i have just found out that the floor in the house we did approx 8 months ago has expanded to a point were it has caused the skirting boards to become detatched from the walls
it has even buckled in the hallway to the point were the guy has had to take a length of the flooring out to get it to lay flat. i think this bit was where the floor was really unlevel so it hasnt stuck properly but this is not the case for the house i did as the floor was perfectly flat
anyway guys, im worried about this expanding issue and im worried now it will do the same in my mates mums house. what do you think the chance are of it happening?? should it have been layed this way?? what should i do if anything to ensure it does not do any damage.
hope you can help guys. any advice appreciated
