Fitting a diagonal / corner door.
26 Mar 2010
Worcestershire
Not the most descriptive and helpful subject and for that I apologise! :|
Am boxing off the corner of a room to become an en-suite however rather than put the door in line with a wall I want to maximise the space in the room and put the door at a diagonal but am unsure how the door frame will work.
I have attached an image which may explain things clearer - a picture speaks a thousand words!! It is the diagonal gap between the 2x 850mm walls that will carry the door
View media item 52487
Cheers
Ian
perhaps you can get this to work using some harris rail fixed to the wall ends then fix the d/frame to them?
iirc you would normally have a couple of small nibs comming off for the frame to fix too.
same shape as shower pods that are craned in on student accommodation blocks.
