Hi, I've just bought a Honeywell CM927 wireless programmable thermostat and need some advice on how to wire it up to my boiler.
Connection to power seems straight forward, but I could use some advice for the thermostat connection to the boiler.
The instructions tell me to connect the following:
Terminal A (Honeywell CM927 End) to T1 on my boiler
Terminal B (Honeywell CM927 End) to T2 on my boiler.
The Worcester Bosch 280 has 5 terminals decending vertically, the top 2 are for the Frost Stat (I'll call them 1 & 2) - so not bothered about those. The next two down would have had a bridge across them originally (I'll call them 3 & 4) and the botton one is labelled 'N' (I'll call that number 5).
Number 3 has a BROWN wire coming out that goes in to the existing (to be replaced) programmer and Number 4 has a BLUE wire that connects to the existing programmer - I'm pretty sure that they connect to the existing programmer because the original bridge in the boiler was removed - hence the existing programmer is acting as the bridge, which is great for me as the wiring is already in place. Number 5 has no wire coming out of it.
The Question is: Out of 3 and 4, which is T1, and which is T2 - I'm guessing 3 = T1 and 4 = T2, but would like to know for sure
Cheers
Phil
Cheers
Phil
