I am looking to fit a pump directly to the hot water supply feed from the hot water cylinder to solve a problem of lack of hot water supply to a recently fitted shower in a bathroom where there wasn't one previously.
My plan is to fit a surrey flange to the cylinder and vent to the header tank the same as it is at present and then fit the pump directly in line to the hot water feed so as to pressurise the household hot water feed system when in use and making use of a showerforce easiboost pump I already have.
I am hoping to be able to plumb this in with readily available jg pushfit parts and pipe from screwfix and with the flange from wickes
question is to you professionals out there is does that sound ok and viable
thanks in advance for replies
cheers, Kieth
cheers, Kieth
