Finally getting around to fitting a shower pump, though just want to check something. I can easily get access to the hot and cold feeds in the airing cupboard (cold is fed from the loft cold water tank, hot from a separated feed from the hot water tank), so I can site the pump at the bottom of the hot water cylinder without much trouble.
The only issue I'm unsure of is that the cold supply to the shower will go back up into the loft and then down again into the shower. If it makes any difference there is about 4ft between shower head and bottom of cold water tank, the pipe will go up from the pump about 7ft and then horizontally and then down again to the shower mixer, it will be about 3ft below the tank on the horizontal run. The hot pipe doesn't go back up into the loft.
Do you think a 1.5bar pump like the Salamander RSP50 would be OK?
