I'm in the process of sorting all the bits to fit a pump to our shower system to improve the pressure. Currently the cold water comes off the mains and the hot water comes from a traditional unpressurised hot water tank and is controlled by a thermostatic shower temperature control.
The header tank for the hot water isn't huge and i know that pumped showers can use a lot of water, so can i use the current mains cold feed to feed the pump so that only the hot water is fed by the header tank?
Alternatively, can i use a single impeller pump and just pressurise the hot water and again use the mains pressure cold feed?
Thanks in advance.
Thanks in advance.
