Fitting a shower to a combi boiler
19 Apr 2006
I am re-fitting a bathroom.
I have had a combi boiler fitted to replace a broken back boiler.
The current hot water in the bathroom comes from old 15mm pipes.
There are two 22mm pipes coming from the combi boiler - one of which gets hot when I run the hot water upstairs.
I am OK to take a feed to a new shower from the 22mm hot pipe?
Mant thanks in anticipation.
Thanks for that.
I had switched-off the heating at the boiler (to give hot water only) - is that still likely to be the case?
Tee off the hot pipe feeding your basin or bath tap. Should have no probs being as it is combi fed. :D
