Hello people. I wonder if someone can help me. I have a Vailiant system boiler connected to a Megaflo unvented cylinder. I have the Vailiant 360f wireless programmable room thermostat. This is connected via a VR 65 control unit.
Everything else seems to work fine but I can not get the on demand hot water top up to work. I press the 'F' key four times, the tap symbol appears on the display but the water does not heat up.
I have done a search on the web and it seems that the reason for this is that the VR65 unit needs to be connected to the VR10 NTC thermostat and not the standard thermostat that is on the hot water cylinder.
I have checked the box of bits I have left over from the installation and there is indeed a VR10 NTC in there.
The VR10 NTC is normally fitted to a dry pocket on the Vailiant UniStor cylinders. I am assuming that the Megaflo does not have this dry pocket for me to connect the VR10 NTC to.
Someone suggested that they just cut away a small section of foam on their standard cylinder, and attached the VR10 NTC using some heat transfer paste and then covered it up with silicone.
I looked at my cylinder and it has a plastic/metal coating on the outside. I assume there is foam under this.
My question is has anyone ever fitted the VR10 NTC to a Megaflo cylinder before and would you advise it. Also how easy is it going to be to cut a section of foam out so that I can fit the VR10 NTC thermostat on the inner metal tank?
At the moment if the water goes cold we have to change the scheduled time the water is due to come on at.
