fitting a vertical flu kit
8 Jun 2008
Bristol
Hi i have an ariston Combi A 30 mffi boiler and i am getting it re sighted and it needs a vertical flu kit.
The only problem is there are a load of different parts and a kit.
I have no idea if i need the flu kit, and the vertical starter, and the flashing and the brackets and the terminal. or whether the kit contains the whole lot, and then all i need is a couple of extension pieces.
http://www.ariston.co.uk/uploads/doc47c2e311b9466.pdf
I have a feeling the flu kits are common to all ariston boilers so was wondering if anyone has fitted one before and had any tips.
cheers
Adrian
Not had any experience with Aristoffs but I suggest to call them. They will tell you what you need and what comes in a box.
