As you probably know, a break out kit is required. The above is just an example. Have you got a kit? Because your can has a network (CAN) controlling all the electrics you just cant wire into the back lights.
Always double check with the supplier that it is compatible with your car.
Usually the instruction are pretty good, if you are into electrics
If not, all the tow bar fitters will do it for you
Hope this helps
PS If you have a kit and are getting stuck ask whatever it is you want to know?
