Fitting UPVC door
19 Nov 2008
Dorset
I'm about to fit a new UPVC door.
Just checking! Is this correct, that I fit the frame, check it's square, pack where the screws will be, drill and screw 2x rawl screws at each side, one top and bottom, fill gaps with foam, tidy up foam?
How much foam for a gap app 10-15mm?
Anything else I need to do?
Cheers, Camerart.
You'll need more screws than that! At least 4 up each side depending on its overall height.
