Fixing camera to flat roof or to tiles
  • Thread starter Thread starter bsr
  • Start date Start date
bsr
5 Aug 2008
Gloucestershire
Hi
I have some construction work starting soon. It's a bungalow with a flat roof bay. The front of the house is busy with guttering, lighting etc and I've identified the best mounting points for a dome CCTV camera as either:
1. On the bottom row of concrete roof tiles
2. On the lead flat roof of the bay
Any suggestions how I could mount to either? If I glued the camera to the lead with lead mate would that have suitable resistance against wind uplift?
Can’t think of two worse locations .
Whats wrong with facia under gutter .
No the camera is to cover the drive, gate, where the skip will go etc. insurance company told me I'm at a higher risk of burglary during work due to the big hole in the house. Makes sense!
Is it temporary? If so you could screw it to a plank and leave that on the flat roof. As you say, LeadMate... otherwise a bracket to/around the fascia/soffit?
  • Thanks
Reactions: bsr
Yes temporary. A plank sounds like a good idea, I have half a gravel board somewhere...
and stick a couple of concrete blocks on the plank to stop it moving in the breeze...........
