Fixing plastic back box to damaged plasterboard wall
4 Oct 2012
Devon
Recently had my house rewired, and following this, a plasterer worked throughout, skimming in some areas, and others fixing dry walling.
In one location, he relocated a hole for the socket with the wires hanging for me to install a plastic back box (with retaining clips).
However, he cut the hole perilously close to the vertical timber behind the stud wall, so I've had to chip out some of the timber to allow the clip on the back box to slide back to lock behind the plasterboard.
Unfortunately, some of the plasterboard surrounding the hole is damaged, and the clip can't get a good fixing to this - can anyone suggest a quick way to offer some support to this inside the wall to allow the back box to clip in with a solid fix?
Someone has suggested mastic-ing some plastic glazing packers (2mm thick plastic) inside to give some support.
Any ideas please!
If it is beside a timber then just whack a woodscrew through the side of the plastic backbox into the timber and use the clip on the other side.
You might have to remove some of the clip plastic to be able to still use the screw thread, but it depends on the box.
That's a great suggestion!, thank you.
Only problem I can forsee is getting inside the hole enough to get a screw into the wood - I have an electric driver but not sure it will fit!
O course it will, just screw it in at an angle. Drill an angled hole in the side clip and screw through into the stud, That'lll hold one side and the normal clip will hold the other.
Its a regular occurance round my way!!
