On very weak walls I use 12 mm or 18 mm MDF behind the rad and fix this to the vertical timbers.
On very weak lath and plaster I have sometimes used the multiple fixings method. I drill about 12 holes in the bracket and use 12 screws. Individually each screw is very weak but with 12 -14 it can give an adequate fixing.
