- Joined
- 14 Nov 2017
- Messages
- 5
- Reaction score
- 0
- Country
Hello,
1st time poster, so I'll try and give as complete information as I can, all help appreciated.
I've just moved into a house and at one part of the living room, the mdf was so bevelled away from that wall that there was no way it could be filled in the normal way.
Looking closely at it, the skirting had been glued on without the use of any nails, and over time the kink in the skirting had pulled itself off of the wall.
There was no way I could push the skirting back to anywhere good enough to fill.
The problem gets worse as the plasterboard was dot and dabbed onto the breezeblock inner wall, so there isn't even a wood baton to try and screw the skirting onto.
Also, the plasterboard under the skirting had also broken due to the skirting twisting.
So, I've removed the section of the skirting and now have to work out a method to get it back on.
The floor is concrete, so I either need to leave a gap in any replacement plaster I put behind it, or use something that is impervious to moisture.
My current thinking is to use some expanding foam on the bottom (effectively creating a gap), patch up to the plasterboard above, and then re-glue a replacement piece in.
If I can't get a decent match on the skirting, I will saw slots down the back of the removed piece to try and relieve the bowing.
Does my method sound viable, or is there a better way or better product to use?
Steven
Steven
