Fixings for lighting bar into ceiling above? (50KG load)
28 Jul 2012
Surrey
I need to mount a 2.4 meters long section of 50mm x 25mm mild steel box section into the ceilings joists where it will support about 50kg of disco/stage lights. I also can't easily get above the ceiling due to a room above.
There also needs to be about 100mm between the top of the box section and the ceiling.
The M12 x 250mm coach bolts here: http://www.tradefixdirect.com/screws-accessories/coach-screws/bzp-coach-screws would do; but are rather expensive at £20 when I only need about 4 or 5.
Any ideas; Are Rawlbolts sutiable for hanging heavy loads from the ceiling?
Edit: My joists are about 40mm wide.
Coach screws are what you need here.....so long as you can screw directly into the ceiling timbers.
Are you going to use a tubular spacer, or something to provide you with the gap you need?
John :)
Expanding bolts are really for masonry.....coach screws are what you need, for that sort of weight.
John :)
Sure, so long as you hit the joists! Forgive my caution, but that sort of weight crashing down is best avoided!
John :)
Especially when it will be directly above my bed! (i'm serious)
Whether it's a 13kg Moving head above my bed or above a stage, you just as doomed if it falls and lands on your head.
I will be hanging these + a couple of led par cans. (see photo)
