- Joined
- 28 Jan 2010
- Messages
- 641
- Reaction score
- 75
- Country
When you say "testing for continuity", what do you actually mean? I don't think you understand.
As has been said, you can't test for continuity with power on, because:
1) All the unnecessary dangers of live working
2) You will not get an accurate reading
3) You will destroy your meter
4) You can destroy yourself
As Mikey said, when you're testing resistance with your multimeter, it supplies a very low voltage (a couple of volts) to the circuit you're testing, measures the very small current that this very small voltage causes to flow, and calculates the resistance in ohms.
When you've shoved the probes across L&N or L&E, this very small voltage is increased to 340v (peak), the very small current becomes a very large current, your meter says bye-bye, quite possibly any sensitive electronics says bye-bye, and you are feck1n lucky that you didn't too.
The only testing you should be doing live is VOLTAGE checks, NOT continuity.
PS. I am glad you are still alive to type this post.
