- Joined
- 4 Feb 2015
- Messages
- 7
- Reaction score
- 0
- Country
Hi All,
i am having issues with flat roof . we've had 'roofers' round twice and problem still exist so im here to see what else can be done with it.
roof is covered with metal sheet (antidrip) at angle of 3.5 deg and it seems not to drain quickly enough at the bottom. water drips into house (see pics). we had sheets lifted and it looks like water is being pushed back under sheet up to second row of battens where it stops and sips through insulation and down the walls. roof built with 225 rafters, 120mm insulation, one set of 25mm battens so plenty of air to dry bottom of sheet however it's just not happening. as per pics there are seals and drip strips at the bottom to prevent water going back. it appears problem is worse when light rain or snow melting as water not flowing fast enough???i dont know anymore. red circle indicates where problem is worst . it is happening on both bottoms(short and long run of the roof). please help....Andre
View media item 89470 View media item 89471 View media item 89472 View media item 89473 View media item 89474 View media item 89475 View media item 89476
