Flat Roof
8 Aug 2023
Question I had a flat roof designed wrong/build and trying to find the "correct" answer to fix it.
Currently have the roof build as follows
Joist 200mm @400 Centers
75x50 firings
18 mm OSB
Membrane
50mm PIR insulations
18mm OSB
oprema 3kg per
5Kg per cap sheet
No this doesnt meet the Uvalues
can i just do the following:
3mm skin
12.5 plasterboard
20mm PIR under joist for no bridging
100mm PIR between Joist
75x50 firings
18 mm OSB
Membrane
18mm OSB
Soprema 3kg per M
5Kg per cap sheet
50MM ventilation gap between first 18mm OSB and 100 PIR insulations between the joist
or do we just put 100mm PIR ontop and refelt ect
75x50 firings
18 mm OSB
Membrane
18mm OSB
oprema 3kg per
5Kg per cap sheet
3mm skin
12.5 plasterboard
75x50 firings
18 mm OSB
Membrane
18mm OSB
Soprema 3kg per M
5Kg per cap sheet
Put 100mm on top. Yiu dont want to create a cold roof - thus creating the need for additional troublesome venting.
I would ask them see if they'll accept it, bit of a hybrid, not too disimilar to what is sometimes done on a garage conversion where the existing roof finish has stayed on and ventilation would have been dificult to achieve.
