flatroof refelting
2 Oct 2004
flat roof needs refelting but has orginal lead layer underneath
which method to use ? 2 layer or 3 layer refelting ?
roof aprrox 2m x 2m cost of recomended materials ?
TIA
rip it all off, lead as well. renew in 3 layer system topped in lime chippings.whilst it's off check boards make sure they are firm and if you can check for insulation.local roofing yard will tell you what you need.lime chippings cover approx 3sqm per bag.don't be tempted to buy from one of the sheds.open all hours but mega expensive
Stone chippings are a thing of the past!....Mineral finish is what you want,a decent quality 2 layer system will do the job..
Well put it this way,in the past ten years( been in the game over 27 years) of flat roofing I can count on the fingers of one hand how many jobs I've gritted....Whereas mineral finished roofs are concerned it must run into the hundreds,so doesn't that indicate that chippings are a thing of the past?...
[Stone chippings are a thing of the past!....Mineral finish is what you want,a decent quality 2 layer system will do the job..]
This 2 layer system - is that like a 4mm underlay put over the existing felt (after removing the chippings) and finished with a mineral felt top layer?
I've had a couple of quotes for my 25sqm garage / front porch and the first was to remove and replace all the felt with new mineral finish type (£630+), the second is just to do as described above (£580 inc).
I'm not looking for the cheepest quote just a good job that will last.
