I need to use a 300mm flexible/bendable 15mm copper pipe (the corrugated type that looks like a coil) but I have read that the copper is only 0.6mm thick and therefore weaker than normal 0.8mm copper.
Would it be okay to use a plastic insert to strengthen it for compression and push-fit at its two ends ?
Thank you.
Thank you.
