I need to cut a 110mm soil pipe and re-connect using a flexible connector.
Toolstation sell 100mm and 150mm flexible connectors
http://www.toolstation.com/documents/search/index.html?searchstr=flexible+connector&submit=Go
I'm confused about sizing. Would the 100mm work for me. I have the standard grey pipe with a brown 90 degree elbow. The joint is leaking condensation and with limited access I considered the best solution was to cut the 2 pipes either side of the joint and reconnect with this flexible connector?
Is that wise or should I dig a hole in the wall (which risks further tiling damage) and just replace the elbow..
Thanks for looking..
