- Joined
- 8 Mar 2010
- Messages
- 348
- Reaction score
- 8
- Country
What ho one and all,
When I built our house, I installed a Flexit L4X (sometimes labelled as Helios KWLC 350) ventilation and heat recovery unit. Has been working fine for 12 years.
Recently, when it comes on, the upper Alarm LED on the control panel is illuminated; according to the instruction manual, this relates to the overheating thermostat. By turning the unit off, resetting the thermostat by pressing the reset button and turning on, all is fine. And perhaps it will be fine for the next running cycles, but it also may not and the overheating alarm will display.
There are two stats next to each other on the air inlet side which I understand to be related to frost protection; one has a reset button, the other does not. The stat with the button has continuity so I assume is working; the other has no continuity, so perhaps it needs replacing?
This evening, it started with no problems so I checked the stats continuity. Still the same as above. Disconnected one wire on the reset stat and of course, the unit stopped. Started it again and disconnected the cable on the other stat without the button and nothing happened, the unit continued to run.
So I don't know what is causing the overheating warning. Should both stats have continuity? If one does not, why is it installed?
Should I replace the non-continuity stat?
Grateful for your suggestions.
Thanks and toodle pip
