Hi there,
I'm having about 30m2 of 15mm bamboo fitted as a floating floor, using 5mm fibreboard as an underlay. Two or three areas of the floor are pretty uneven I think with some loose floorboards (its the 1st floor).
My fitter is a reall professional guy, and has been really helpful. It's getting close to the fitting and I'm just wondering if I should approach him about having the floor glued or nailed instead of floated. This is considerably more expensive than standard floating and I just wanted to get people's views on whether I should go for it or not? Can the bamboo still be nailed with the 5mm fibreboard underneath?
