Floating Floor Replacement Options
7 Jan 2010
Hampshire
We have a floating floor which springs a lot more than I would like. In our previous house we replaced a similar, albeit slightly different, floating construction and I’m trying to figure out what options we have.
Current floor appears to be block and beam, then 100mm Celotex with chipboard T&G on top. Previously we had block and beam with no insulation, 50mm batons and finally chipboard T&G. We took that woodwork out and screened the whole lot. I’m assuming however that that isn’t quite so simple at our new property as building regs means the full 100mm Celotex has to remain with screed on top. This would obviously raise the floor level.
Are there any options for replacing a Celotex/Chipboard floating floor with a solid screed that retains an acceptable level of insulation without adversely affecting finished height?
I converted a garage for a customer so I screeded the floor flat with sharp sand, cement, SBR mix. Then a DPM sheet with celotex insulation and T&T chipboard. Between every single surface between the DPM, insulation and boards, I drowned it in PVA. It was like walking on a solid floor.
