Floetrol
Discussion in 'Decorating and Painting' started by ando, 5 Jan 2014.
  1. ando
    ando
    3 Nov 2008
    179
    Thanks Received:
    2
    Hertfordshire
    Country:
    Has anyone used Floetrol in vinyl Matt emulsions and if so have they had good results with it or is it only really good for water based trim paints and is there any downside to using it
  2. stevewestern
    stevewestern
    3 Oct 2012
    128
    Thanks Received:
    15
    Cornwall
    Country:
    I use it in acrylic trim paint, but never felt the need to use it in emulsion as diluting it with water does the job.
    It does as it claims - helps reduce brushmarks and keeps the wet edge longer so is worth the cost for me. The only downside is the extra cost but as I said, it is worth it for me.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. dcdec
    dcdec
    14 Jan 2011
    1,475
    Thanks Received:
    408
    Hampshire
    Country:
    I've used it a bit in hot weather with trim paints, its ok i guess. You have to be careful to only decant about an hours paint at a time as the floetrol can make your paint go stringy. Apparantly xim is better but not used it. Did try floetrol in some emulsion to stop it drying as it hit the wall, i didn't think it made much difference, but that said i'm never really sure how much to put in.
    • Thanks Thanks x 1
  5. stevewestern
    stevewestern
    3 Oct 2012
    128
    Thanks Received:
    15
    Cornwall
    Country:
    I should have added that I now use xim latex extender more as floetrol has gone stringy once or twice.
    As dcdec says, just add to what paint you put into your kettle - I use about 20-25mm per litre roughly, but it is more a 'how-it-feels' thing - you sort of know when paint is the right consistency, and it shows when you apply it, as it just goes on right !
    • Thanks Thanks x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Related Threads
  1. curium
    6
    5,648
Share This Page
