Question for y'all. A couple of years ago I installed a florescent light fitting with a 2D type bulb in it. This light is on pretty much 24/7.
I took the diffuser off today to paint around it and noticed that all the plastic within the light unit has gone brown - UV damage I presume?
The twin and earth coming into the fitting is slightly discolored as well - presumably the same UV problem?
Should I be worried about this? Should the cables be shielded from the lamp?
