Friend of mine has a florescent kitchen light (2 way switching) and every now & then when come to switch on the light there's a bang & a blue flash seen around the switch area and trips the mcb lighting circuit. Once reset he said it can go several weeks before doing the same again. I replaced one of the switches and after another few weeks of working ok it did the same & tripped the mcb - only this time when he reset the mcb it blew again as soon as he went to turn on the light (this time using the other switch on the opposite side of the room). For now he's using lighting from the kitchen sockets until he gets the problem sorted.
Sounds like it's shorting out somewhere but I couldn't see any damage to the cable / insulation when I replaced one of the switches. I don't know if this is just coincidence but he said it started to happen after changing the starter in the light so not sure if it could be a problem with the starter, ballast, light fitting or wiring. Any pointers welcome.
