Firstly what is the correct terminology for this part? http://www.screwfix.com/p/comap-flushcone-internal-clear-pvc/44988
Now the problem:
I have a low level concealed cistern and the flush pipe is a pain in the arse to fit in to the connection at the back of the WC via rubber flush connector.
The flush pipes is going through vanity type unit and a bit difficult to be sure it fits snug.
So any tips on this, would it be advisable to cut in to the flush pipe as this is one piece (elbowed) and then fit straight cut section in to the pan flush inlet, then push back and make a coupling within the unit. Would any sealants help at the pan inlet as it does slightly leak when in place at the moment or it just not sitting right?
Now the problem:
