Hi
Many thanks in advance for your help.
I’ve a 10 year old system with a Remeha Avanta Plus 28C boiler with 6 radiators. Only one radiator has a drainage tap - it is the only one on a floor below all the others. I have drained the system and run X400 through it with the heating on constantly for ~30 hours - all rads open. Didn’t have time to run for longer unfortunately as the work needs to be finished in the next few days. Then drained, filled and run for 15 minutes, drained, filled and run for 15 minutes and drained again. Water is still very brown but I guess that’s no surprise.
Just wondering if I should do more beyond re-filling and adding X100? One thought is to turn off all the rads except one, leave the drainage tap open and then turn on the mains through the filling loop and wait for it to run through clear, then move on to the next radiator etc. If I do this should I turn off the inflow and outflow valves to the boiler? I’d rather not take off a radiator if possible.
Thanks again!
Fred
Thanks again!
Fred
